Mount Question ???
civic_types
For a 92-95 Will the D16 series mounts fit on a B16 for a swap ?!?!
Especially the driver's side mount ?? And Tranny mount ???
Thanks in advance
no. ive done the swap several times. you need the driver side mount and a tranny mount from a b series.
Mine were exactly the same. The only different ones were the front torque brackets (use the D series rubber mounts) and the rear engine bracket (use the Civic rear rubber mount)
thats strange... i've never heard of d series mounts working with b series motors... the rear tranny mount works.. but you need a different bracket from the tranny to the mount..
on mine, i also had to change the front bracket (between the head and the mount)
