mount?
Discussion in 'HYBRID -> ED-EF / DA' started by joesefcivic, Jan 19, 2004.
  1. joesefcivic
    joesefcivic Senior Member
    ok i got a 91 civic hatch with a stock d15 in it.
    im about to do a b16 swap and i noticed that the rear mount bracket was different. i was wanting to know what mounting bracket i need for that. i was going to get a 91 teg mount bracket from a body of mine but wanted to make sure that this was the right bracket. if you've done this then let me know asap.
    thanks joe
  2. hybrid89
    hybrid89 thistownsucks...
    SoCal
    Get a stock 88-91 Civic/CRX Si mount and move the mount to the holes closer to the drivers side.(there are 2 sets of mounting holes in the rear cross member. Its as easy as moving it overa s long as you have the right mount to start with.
    matt
  3. BigJ
    Don't you need a mount kit? Or atleast I thought you did. :blink:
  4. joesefcivic
    yeah i got the kit i just need the bracket.
    ok that should work if the brackets the same. thanks
