Bobby17772
Member
I have a dumb question. Do eg mounts have the same bolt pattern as the ef? Because tomorrow I'm picking up a full single swap (only wanted the engine for I'm buying everything for 120) and it comes with the mounts to and I was thinking if it has the same bolt pattern because if so I might as well use them when I take the motor out to take the mounts with it.
thanks
thanks
