b18b with auto going into an 97 civic that currently has d series auto.
can someone point me in the right direction regarding the mounts, so far the ones i found arent clear if they will work for auto or not, are they the same mounts?
The only mounts you will need are the rear t bracket and the drivers side mount BRACKET(not the rubber ball thing) from a 99-00Si. You may also want to get the two front torque mounts from a 94-00 Integra but you don't have to have these. As far as your tranny mount it should bolt up because both components are from an auto.
I frieken love it when people respond to my posts in their threads, it proves that they heard what i said. Thank you very much, good luck in you venture.
