mpfi swap problems
Status
Not open for further replies.
RcRacing72
So I'm doing a mpfi swap on a 91 std hatch.
Ive modified that dx harness, (tps sensor and eacv plug)
I ran c1 and c2 into b10 and b12
Ran c1 and c2 up to blue/yellow blue/green for the distributor.
I ran all my injectors seperate.
I tested all these wires from the ecu to the connection with a volt meter and there is no break in any of the lines I ran.I matched the distributor layout with the plugs for the distributor to my street car(91civicsi) and they are in the correct spot. This car ran before I did the swap.
I'm getting no spark to my distributor, but it is getting power. I tested the ecu.
Any ideas?
Ive checked my wiring a handful of times.
thanks.
Status
