MSD ignition
i have a h22a with cams pstions rods header intake and a few other things i want to put msd igntion on it but im not sure which one to use 6a 6al ... dose anyone have any suggstions and how hard is it to install thanks for your help
Originally posted by xyswany@Oct 2 2003, 10:38 AM
MSD 6AL unless your planing on mounting it inside the car,
:withstupid:
that's all you'll really need, unless your going to be using a turbo at sometime.
ive searched before for any dyno proof that MSD ignition actually increases power..and found nothing. they claim it does in their ads, but have no dyno charts to show. also, ive read expert advice that said upgrading your ignition only adds power to turbocharged or supercharged engines...because you can greatly adjust the timing.
even if they do have a dyno I would have to see it person, dynos are all different from car to car, and they might not even list if they added anything such as octane booster, higher octane rating, or even bump the timing
