Msd On 90 Civic Hb
Discussion in 'General Tech and Maintenance' started by Kakarrott, Mar 26, 2003.
  1. Kakarrott
    Kakarrott Member
    I need some info on what exactly i need to install MSD ignition controller and how to install it in a 90 Civic hb with a JDM B16A first Gen
    i went out to buy some stuff the they sold me a 90-91 civic/crx/integra MSD distributor Pro Cap and MSD spark plug wires
    a blaster coil #3 now they say i need the MSD 6AL controller is this CORRECT or is the coil the wrong one.Any LINK on how to or any help would be appreciated ....... THANK YOU.
  2. pissedoffsol
    the cap won't work. thats a d-seriies part.
    return all of it. its useless.
  3. chevy302dz
    chevy302dz Senior Member
    :werd: Send it all back and spend your money elsewhere, you will not see a increase in power from this setup.
  4. Kakarrott
    Kakarrott Member
    dammit i cant send it back its all open now fuck im screwed now.They told me i can make this work can u explain why i cant make it work, the distributor cap is the right one cuz if i want to cahnge the cap i need a 90 integra and this MSD cap is for 90-91 civic/crx/integra if not wich is the right one PISSEDOFFSOL.Here is there site MSD were it says how to install in to a honda but i see no coil. http://www.msdignition.com/ ((((((((((( install in honda )))))))))
    i really need to know if it is slightly remotly possible to make this setup work i saw a pic of a 90 civic with this setup cap coil controller wires i will look for the pic again and post ..........THANKS http://www.geocities.com/cadmando18/MSD-Ignition.html here is the pic of the civic with the setup only thing i see diffrent is the coil do u think i need a diffrent one i have the
    BLASTER COIL #3
  5. chevy302dz
    It's not that you can't make it work it is that there really is no benifit from it. The 6al box is the actual control box, the coil is just that a regular ign coil.
  6. Slo86GT
    Slo86GT Super Moderator
    Memphis - Hellhole of the South
    First gen B16a distributors use the same cap and rotor as a D16a6, the stock engine in the Civic/CRX si from 88-91.
    I have a CRX MSD cap on my engine, and a blaster coil... THat's all I've needed so far up to 275 horse power.
