MTF fluid chage
Discussion in 'General Tech and Maintenance' started by Tein, Feb 23, 2009.
  1. Tein
    Tein So much with a little D
    Kissimmee, FL
    How many qt. do I need to fill the tranny thru the speed sensor? I want to avoid the remove of the filler bolt... More easy thru the speed sensor...
  2. Tein
    Kissimmee, FL
    Any one knows? it 3 qt. would be enough?
  3. MthaFuknGreen
    Lodi, CA
    it should be 3-4 qts for a refill.
    if your engine is anything like mine, the speed sensor would be the most difficult route to filling the transmission.. lol
  4. Tein
    Kissimmee, FL
    the Tranny is totally empty cause it was a swap from auto to manual so for know I will drop 3 qt an later on I will check the filler bolt... Thanks
  5. MthaFuknGreen
    Lodi, CA
    initial fill is closer to 8 qts.
    is it a brand new transmission?
  6. Magana559
    Magana559 The Warden
    fresno Ca
    Isnt it like 2.3 Qts? 8 Qts is way too much any way so WTF are you talking about?
  7. spiritofjosh
    spiritofjosh know your role!
    ocean gate nj
    i just refilled my trans and it took 2.5 qts, i dunno who the hell can fit 8 qts in theirs
  8. MthaFuknGreen
    Lodi, CA
    you two obviously dont know what initial means..
  9. bighavic
    bighavic New Member
    Just 2.5 quarts will do but its best to use the filler hole since that will give you the most accurate amount of fluid needed once it starts over flowing. You don't want to overfill!!!
  10. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    And you obviously don't know what MTF means. You're thinking an initial fill on an automatic transmission...
    To the OP, 2.5 quarts is what you need.
  11. Magana559
    fresno Ca
    Well If it means dumping 8qts of MTF in the tranny and letting 5.7 qts Spill all over your drive way then......Sure go for it.
    OP go to honda and buy 3qts of MTF and you will be fine.
  12. Tein
    Kissimmee, FL
    The tranny its not a brand new or out of the box, it's came out of a Civic 98 ex (S40 tranny), it was open to change the bearings, seals and a good cleaning. I drop Yesterday 3 qts thru the Speed Sensor and after I drop all 3 it's look full already... Eventually and before I start the car I will need to open the filler bolt just to make sure that I do not overfill the bitch....
    And My friend even if it is the first time or not 8 qts are to much, keep in mine this is a 4cyl. but thanks any way for reply to this thread...
  13. MthaFuknGreen
    Lodi, CA
    from what ive heard, it doesnt matter if you overfill a manual transmission.
    in fact, ive heard that you should keep pouring until it starts overflowing.
  14. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    Yeah; it starts overflowing out of the fill hole....which is set at that height for a reason. That's how your supposed to fill it...so if you fill it correctly then it's impossible to overfill it. From my experience, buying 3 quarts is enough for any Honda transmission; as the requirements are usually from 2-2.5 quarts.
  15. efhondakid
    Akron-Canton, Ohio
  16. Magana559
    fresno Ca
    HA HA HA HA!! Oh man that show is so old! Awesome post! :laughbounce2:
