much needed info on doing a 95 civic gsr swap
Discussion in 'Civic and del Sol - EG and EK' started by 360danny, Aug 21, 2011.
  1. 360danny
    360danny New Member
    it has the obd2 non vtec 1.6zc 5spd hydo tranny.i just bought a obd1 99 gsr motor. with a ys1 cable tranny can you convert cable to hydro,what else will i need
  2. RHDism
    RHDism Right Hand Drive guru
    Assumingly the EG is already equipped with an OBD1 to 2 ECU jumper. Although since the GSR motor is already OBD1 you wont need it.
    Of course you can convert, but your better off finding a hydro. They can be a little pricey but there are a ton of them out there. You will need a OBD1 p72 ECU or equiv, and add your vtec wires assuming the EG is not an EX. If you can afford it, I would suggest chipping a p28. A fairly simple swap otherwise. GoodLuck;)
