must rev when starting the car then idles 1500
Discussion in 'HYBRID -> EG-EK / DC' started by terribl3jon, Mar 20, 2005.
  1. terribl3jon
    terribl3jon Junior Member
    i put a jdm single in a 92 hatch.. when you start it up you have to rev it a few times so that it doesnt die then it idles at 1500rpms. there is a loud hissing coming from the intake.. does anyone have any thoughts on this? thanks
  2. TWISTEDIMAGE
    TWISTEDIMAGE Senior Member
    CASPER WYOMING
    uh vacume leak
  3. TWISTEDIMAGE
    CASPER WYOMING
  4. DelSlo
    DelSlo Senior Member
    ughhhh vacuum leak!!??!?!
  5. nfn15037
    nfn15037 Senior Member
    Probably the FITV on the bottom of the throttle body. Try pulling the intake off and putting your finger over the hole in the throttle body, it will probably idle down like normal. Inside the FITV there is a piston thing that just needs to be threaded back down into its bore, or you can just make a blockoff plate for it and throw it away.
  6. terribl3jon
    actually the fit valve was my first guess and though it still continues to suck in air after the car has warmed.. the idle doesnt change when i cover it with my finger
  7. CrazyAzn
    CrazyAzn Senior Member
    check the pcv valve, that freaken 3 dollar piece of plastic cost me 3 weeks of head aches. so yeah u might wanna check that out or just replace it for kicks, because after all it is only 3 bucks.
  8. b204dr
    b204dr Senior Member
    Minnesota
    myne only did that when it was extremly cold - i would think fitv as well
  9. b16eg6experiment
    b16eg6experiment Junior Member
    you've tried the starter fluid trick to locace the leak, right.
