My 1990 Hatchback Wont Move - Help!
Discussion in 'Civic and CRX - EF' started by NEWBIEDAN, Jan 3, 2008.
  1. NEWBIEDAN
    NEWBIEDAN New Member
    Vancouver, WA
    Help!
    I Have A 1990 Civic Hatchback, Std...
    I Havent Had This Car Very Long At All And This Is Definately The First Honda Ive Ever Touched. I Am Very Mechanically Enclined... Let Me Start With Whats Going On...
    I Started The Car.. Put It In Reverse.. Pulled Out Of My Garage.. Clutch In... Put Car In 1st Gear... Let Clutch Out. Nothing!!! Can Hear A Little Hum And I Can Rev It Up And Speedo Goes Up Just Like Im Driving.
    It Did This To Me Once Before Than I Let It Sit A Couple Days And It Was Fine. Been Driving It Ever Since. Til Today.
    Im Assuming Its Not The Clutch Because I Can Put It In Forth (its A 4 Speed) And Rev It And The Speedo Goes Up To 70mph Like I Was On The Freeway!! So Im Guessing The Clutch Is Working.
    I Dont Think Anything Internal In The Tranny Could Fail Intermittantly And On Top Of That... Not Make Nasty Noises
  2. jlicrx
    jlicrx Senior Member
    Colorado Springs
    sounds to me like you have an axle that isn't all the way into the transmission
  3. xips(86CRXSI)
    xips(86CRXSI) New Member
    Portland, OR
    YEP :thumbsup::yes:, I would look at the axles where they enter the trans, and at hubs.
  4. MXDesa
    MXDesa Senior Member
    Queens, New York
    But why would it go in reverse if the axle was out? Still worth a look!
  5. xips(86CRXSI)
    Portland, OR
    I guessing that it went in reverse popped out the axle and now it won't move at all.
  6. philyphreak2127
    philyphreak2127 Back in the Game
    Littleton, co
    clutch master or slave cylinder?? it happened to me in my integra, except I couldn't get the car in any gear. Will it still go in first?
  7. philyphreak2127
    Littleton, co
    sorry reverse not first. typo!!
  8. 92civicb18b1
    92civicb18b1 The Trisexual
    SOunds like an axle to me as well.
  9. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    +1 for axle.
    My Accord was able to move with a bad axle. Don't know how, but it did....then "came loose" again.
  10. D15Beater
    D15Beater HNFTuning
    Concord N.C.
    On a 1990??? Cable man, cable. When i broke my axle the car did what you are desribing so it may be one of your axles popped out...not good if it did you would be leaking oil.
  11. 92civicb18b1
    I used to bust axles all the time, so I was used to those symptoms.
  12. HATCHET_HONDA
    HATCHET_HONDA scottie fizzle
    hobart, indiana
    was drivin on the highway and an axle popped apart on me! was all like waaaaaaaaaaaaaaa!! goin nowheres.. in conclusion, axels are your best bet
  13. drummingpariah
    drummingpariah Author of the Madness Man
    Bay Area, CA
    Did it make any funky noises beforehand?
    Any previous problems?
    When was the last time you replaced your axles, and were the axle nuts tight? Were they overtight?
  14. phyregod
    phyregod !!YTINASNI
    Central Texas
    Killed an axle on my CRX.
    Same symptoms.
  15. NEWBIEDAN
    Vancouver, WA
    Thanks Alot For All Your Help Everyone, That Was Exactly What It Was... (axle Popped Out.) When I Pulled Out Of My Garage I Cranked It All The Way Right To Turn Onto The Street... Im Guessing The Strain Of That Was Pulling On The Axle And Popped Her Loose... Anyways... Thanks Everyone!
  16. drummingpariah
    Bay Area, CA
    You really need to make sure you put a kink in the axle nut when you tighten it down. That's why they put the little notch at the end of the axle. As long as you do that, it'll never pop out of the wheel-side.
  17. NEWBIEDAN
    Vancouver, WA
    It Actually Came Out Of The Tranny Side, Not The Wheel Side But Thanks For The Reply And All The Help
  18. xips(86CRXSI)
    Portland, OR
    Yep thats all it takes sometimes.
  19. d'sirius ginius
    d'sirius ginius New Member
    make sure the right axle is all the way in
