My 79 1200
Discussion in 'Auto Multi-Media' started by dilbeckskate, Oct 23, 2013.
  1. hondarin
    Texas; where else?
    It would be cool to switch to round headlights though. Oh, and do something about the bumper too.
    dilbeckskate likes this.
  2. dilbeckskate
    dilbeckskate infamous
    Kennesaw Ga
    meh I personally like the 7x6 headlights and it would be hard to find the adjustment cage for the round ones and the 7x6s give you lotsss of aftermarket support, and the rear bumper we are doing a reinforced roll pan the front is still on the drawing board
  3. dilbeckskate
    Kennesaw Ga
    Alright we sat down today at the fabrication shop and came up with some ideas to make new bumpers that go with the body much better than the stock ones we are going to do a steel bar tucked away as a crash bar in the front+rear and a roll pan skin around to connect to the fenders for both to give it a smooth look and still have some crash safety 20170208_140341.jpg 20170208_140724.jpg
  4. get_nick
    Washington State
    did i miss the post where you mentioned color?
  5. dilbeckskate
    Kennesaw Ga
    99 Dodge Viper Red
    get_nick likes this.
  6. TurboMirage
    put some hella 500s in that bitch
  7. dilbeckskate
    Kennesaw Ga
    will probably be leaving the 7x6's in it and putting the hids in
  8. dilbeckskate
    Kennesaw Ga
    Whoo my shifter, bushings, and every single rubber seal for the car showed up today :) 20170208_193620.jpg
    Matts96HB likes this.
  9. dilbeckskate
    Kennesaw Ga
    whoo my fkn fast knob and more wiring came in, almost have everything 20170209_194712.jpg 20170209_194200.jpg
  10. dilbeckskate
    Kennesaw Ga
    thinking about buying a second gen parts car for 4 by 100 conversion and brake upgrade
  11. dilbeckskate
    Kennesaw Ga
    oil pan finallyyy came in, got the vms magnetic plug also 20170211_210817.jpg
  12. dilbeckskate
    Kennesaw Ga
    Not much progress over the last week, im fixing to get ball joints, tie rod ends, and wheel bearings to freshen everything up while doing it 20170215_143149.jpg
    Matts96HB and TurboMirage like this.
  13. dilbeckskate
    Kennesaw Ga
    wow that was cheaper than I thought... buying nice coilver sleeves next rockauto.png
  14. dilbeckskate
    Kennesaw Ga
    ok ive earned my keep guys I need the VIP username tag
  15. dilbeckskate
    Kennesaw Ga
    the engine now has everything ... mannn this fuel rail is going to look niceeee and accept my -6 line in and Fuelab regulator and gauge 20170216_202444.jpg
  16. dilbeckskate
    Kennesaw Ga
    one marker light filled in just needs to be filled with resin and sanded , as you see we are killing the front/rear added reflectors and smoothing the kit out received_10210082944004480.jpeg received_10210083369655121.jpeg
  17. dilbeckskate
    Kennesaw Ga
    Making some good progress :D received_10210211968350008.jpeg received_10210211967909997.jpeg received_10210211966509962.jpeg
  18. dilbeckskate
    Kennesaw Ga
    Should have all the fiberglass work done this week for the most part
    17156332_10158323114255076_5095308140178424948_n.jpg 17103435_10158323114310076_1322780268446576568_n.jpg
  19. dilbeckskate
    Kennesaw Ga
    Rear Reflectors are filled in now also, welded steel panel in place of the light and fiberglassed over soo will not crack etc later
    TurboMirage likes this.
  20. dilbeckskate
    Kennesaw Ga
    should be ready for primer this week
