My 79 1200
Discussion in 'Auto Multi-Media' started by dilbeckskate, Oct 23, 2013.
  1. dilbeckskate
    dilbeckskate infamous
    Kennesaw Ga
  2. dilbeckskate
    Kennesaw Ga
    79 Rolled into the fab shop today :D
    hondarin, TurboMirage and BrutalB83 like this.
  3. dilbeckskate
    Kennesaw Ga
  4. dilbeckskate
    Kennesaw Ga
    Starting to box in mounts TOMORROW !
  5. dilbeckskate
    Kennesaw Ga
    Firewall / Frame Rails / Radiator Support cut/massaged for clearance and making the cross member today as well as beginning to box in the mounts for the swap today ! knocking this shiet out
    46902129_294115034543922_4476248446700879872_n.jpg 46973014_2191030194485301_4191099988756922368_n.jpg
    TurboMirage likes this.
  6. dilbeckskate
    Kennesaw Ga
    frame rails are done , boxing in mounts today
    46866232_254467308582285_5261912975773532160_n.jpg 47075042_936738599865790_30578736923410432_n.jpg
  7. dilbeckskate
    Kennesaw Ga
    Getting there :D had to re-position a little bit for tie rods but this is final resting place :D
    47070727_10161110628700076_1398597752811683840_n.jpg 47001521_584530431976099_519732025393938432_n (2).jpg
  8. dilbeckskate
    Kennesaw Ga
    Cross member and Mounts will be finished tomorrow just waiting on Steel
    TurboMirage and Jeef like this.
  9. dilbeckskate
    Kennesaw Ga
    Driver and passenger and dogbone mounts finished just gotta wrap up crossmemember today , changed headers for clearance
  10. dilbeckskate
    Kennesaw Ga
    Swaps done :D Tube Crossmember Goes In Monday
    20181201_161009.jpg 20181201_160950.jpg 20181201_160953.jpg 20181201_160945.jpg 20181201_160930.jpg 20181201_160926.jpg
    hondarin likes this.
  11. dilbeckskate
    Kennesaw Ga
  12. dilbeckskate
    Kennesaw Ga
    wrapping up tube front lower crossmember :D sorry for potato pic
  13. dilbeckskate
    Kennesaw Ga
  14. BrutalB83
    Rochester Hills, MI
    Wow, what's the ground clearance going to be?
  15. dilbeckskate
    Kennesaw Ga
    low lol but same not its still prob same or higher than it is in a slammed EF civic , obviously I have to be careful driving the car as anything else and its not like im daily driving it . We are going to make a skid plate that comes off the front lower crossmember before its all said and done
  16. dilbeckskate
    Kennesaw Ga
    there was a trade off, do I want the engine high as can be and have a terrible fooked up angle on both the cv shafts or get it close to the firewall as possible and straightest shot for the axles to be straight. I can compensate clearence with putting a real wheel/tire under the car and im going to put coilover sleeves on those kyb's to raise the front up a bit
  17. TurboMirage
    better to have the geometry right, like you said you can always fix wheels and height later.
  18. dilbeckskate
    Kennesaw Ga
  19. dilbeckskate
    Kennesaw Ga
  20. dilbeckskate
    Kennesaw Ga
    can you feel it ? because its in there
