my 90 crx dc
Discussion in 'Civic and CRX - EF' started by crxperiment55, Feb 22, 2007.
  1. crxperiment55
    crxperiment55 xplore
    my 90 crx dx
    i have $1,000 or so to spend on this car.i need feed back on what motor should i drop on it.b16a1 or d16z6
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    wrong area
  3. crxperiment55
    wrong area?
  4. crxperiment55
    what do u mean ahhvtec?
  5. AHHVTEC
    Alabama
    you have the post in the cars for sale area
  6. ls ef
    ls ef New Member
    b16a for sure.
  7. 13g-crx
    13g-crx New Member
    $1000 isn't going to get you everything you need for a b16, it probably won't get you a motor and tranny. I vote for z6 with home made turbo kit. But that all depends on your realistic expectations and intentions for the car. You figure an average of $1500-2000 for 140ish whp (B16 motor, tranny, ecu, axles, mounts, linkage yada yada) or $1000-$1200 for an easy 200whp with the boosted z6. Motor, $200-$300 and the other 900-1000 for turbo stuff and a tune. Just my opinion.
  8. Celerity
    Celerity Well-Known Member
    And I've said this before, but if your blessed enough to be able to buy Blanco's actual setup, you win. It's a beautiful build, top notch everything.
    I'm actually going through my bank accounts for this one.
  9. Celerity
    Blanco 6,666 posts for the win !
  10. 13g-crx
    13g-crx New Member
    If you want to spend $1000 on a z6 and si tranny converted to obd1, I'll sell it to you. I see z6's all the time for 300-400, si trannies for $100. Unless you plan on paying $400 for a p28 you can do it for well under $1000.
  11. 13g-crx
    13g-crx New Member
    So lets just compare motor to motor for now. $500 for a z6/si tranny, $1200-1500 for a obd0 b16a. If you kept both of them obd0 your stiil a whole lot more expensive with b-series. If you decide to go obd1, it'll cost close to the same to convert them both (maybe a bit more for the b16). I've done d and b series motors in my crx and I can tell you I have as much in my mounts, axles, shift linkage and whatnot as I gave for my y8 or z6. I know there's more than a p28 involved in going obd1. I've never seen anyone spend a grand on a stock sohc vtec swap.
