my 91 ef si
Discussion in 'HYBRID -> ED-EF / DA' started by stealthissn77, Jul 28, 2009.
  1. stealthissn77
    stealthissn77 New Member
    tucson az
    alright guys im starting off with a 91 si. the head is blown in the d16 so i picked up a b18a1 figured i could do a reliable ls swap. ive got the ecu, mounts, shift linkage, a friend has helped me with my wireing harness. i still need a transmission, clutch, and flywheel. im thinking an ys1 and ideas? also the front end was backed into by a truck so now i need a hood, bumper cover, drivers headlight and corner lens. interior is really clean all stock. ive managed to pull it all out and clean up the dust, dye the carpet black. exterior paint is faded origionaly black not sure on color any ideas wanting something original but with some flair. thanks
  2. Dark93DX
    Dark93DX New Member
    B.C.
    If you're looking for used replacement parts try here ---> Car-Part.com--Used Auto Parts Market
    If you have Hasports EFB1 mounts then any cable B-series transmission will work, shorter gearing will give you better acceleration and an LSD would be a good idea too.
    Hasport also makes an EFB2 kit for use with hydraulic trannys and hydro-cable adapter.
  3. stealthissn77
    tucson az
    alright thanks for the link the mounts i have are the haSport efb1. my shift linkage is from them as well. but i got it used through craigslist the bushings are kinda worn thinking about a set of password ones.
  4. stealthissn77
    tucson az
    hey ive herd that i need to make a dent in the frame rail for altinator clearance is that true? and exactly where about would i be doing it? do i just use a hammer? thanks again
  5. efhondakid
    Akron-Canton, Ohio
    On the driver side shock tower there is a little 1x1 sqaure hole, just below on the frame rail is where you need to massage with the BFH, dont be bashful with it.
  6. INJEN78
    INJEN78 HS LEGEND
    OHIO
    lol bang that baby in...also go with energy suspension bushings from ebay..theyre like $16 shipped...
  7. 91_stylin_civic
    91_stylin_civic Member
    New Jersey
    or just put on a smaller belt i think a 30 inch belt will give you clearance without having to hammer the car
  8. Dark93DX
    Dark93DX New Member
    B.C.
    It's not that big a deal, I just did it last weekend. Just make sure you have a good sized hammer, when I did it the first time I had to lower the engine in a couple times to test fit it for clearence, ended up with about 1/8" or so.
    It was alot easier to lower the engine in after I had removed the front engine mount bracket on the crossmember, along with the battery tray of course.
  9. efalex
    efalex New Member
    Danville NH
    i have a flywheel if u nneed it
  10. stealthissn77
    tucson az
    alright i went ahead and beat the area out to about a 4" circle it looks pretty good now. ive cut out the front end in mine and have put in a torsion bar for more clearence.
  11. stealthissn77
    tucson az
    what weight is it, how mush you asking, and what would shiping run?
  12. GlassHeadlights
    Calgary, AB
    Hey! We have the same car!
  13. stealthissn77
    tucson az
    :mellow: ha lol yeah except my fender near the door on passenger side is mangled and the drivers side around the corner lens is the same. no driver headlight or lens. hood is tore up pretty bad and bumper cover is cracked beyond repare... hopefully soon ill have my front end looking like yours. just looking for parts at the moment. i just moved from az to northern ms i dont know of any places that i can get anything. if anyone knows of junk yards or decent shops hit me up
  14. AAPcarnut
    AAPcarnut New Member
    it took two different owners to the ef i'm picking up to relize that lol so you can see some rubbing for the old ls and b20 that was in it lol :D
  15. GlassHeadlights
    Calgary, AB
    Well I hope you didn't pay too much for your car, I payed $1000 for that shell. (The stock D16A6 had a thrown a rod through the block.)
  16. stealthissn77
    tucson az
    no worries i picked it up for $800 im happy with it so far all the interior is intact. it even came with the original warnings on the seatbelt connector. transmission and engine block had cracks through the bottem. but i ended up with an 1.6 head
  17. blasterman87
    blasterman87 New Member
    i have a 89 thats black also, paid 500 for it with a rod through the block..lol must be a fault with the d16
  18. GlassHeadlights
    Calgary, AB
    Mine was ran out of oil, but the d series do have weak connecting rods.
  19. stealthissn77
    tucson az
    so i just picked up a y1 transmission dirty as hell but ill clean it up and give it a coat of paint. not bad for $120 still looking for a drivers headlight corner lenses flywheel and clutch. i think ill get a clutch on ebay i believe their about 90 bucks.
  20. crvtec90
    crvtec90 New Member
    There is a bracket on the front crossmember (right in front of the radiator )for the front mount that does not get used. I would cut it out before u put the motor in.
