My 91 si
BigT91
I have a 91 prelude w/ a b21a1(hole in block) and i was wondering if any b-series motor would fit in the bay or do i need to buy mounts! i know that the b20b/z will fit no problem but i want either a b16 or gsr b18c mainly but the b20b/z will work
i also need a motor so much help is appreciated! thnx much
no motor will fit in there other than stock with out custom motor mounts and custom everything
No, they won't. Absolutely NOTHING except for another B21 or a B20A will bolt into your car's engine bay. B16s, B17s, B18s, B20B/Zs will NOT work without custom fabrication...
do a h22 but you will be in for some work but the end result will be rewarding
