bossman032
my car won't rev more then 3.5RPM.
no engine check lights car runs fine idle no problems.
only thing is I cant rev more then 3.5.
my car is a STD Civic with A OBD1 motor. I tried to reset the ECU by taking out the fuse and unplug the ecu that didn't work...
what can be causing the problem the speedometer works fine. but I cant rev past 3.5 it bogs.
Edit: car does not BOG its just cant rev more then 3.5 it does not want to go more!!!
please let me know what I can try..
thanks
link to pictures of my swap.
thanks
