My B18c1 Build
Discussion in 'Engine Building' started by LifeSucks88, Sep 4, 2010.
  1. LifeSucks88
    LifeSucks88 New Member
    I was going to do a LS V-Tec but a got a killer deal on a B18c1 block today:D$50.00.
    I drop the block at the shop to have 0.022in milled off the deck height to make the same height as the b18a block and it being bored to 81.50mm
    Parts list
    B18A/B SRP Pistons 9.5:1 but with B18c1 head milled 0.008in makes it 10.27:1 Static Comp Ratio
    b18A/B Brian Crower Econo Rod
    Zero balanced B18a Crankshaft
    ACL RACE SERIES Rod & Main Bearings
    New ITR Oil Pump From Acura
    Golden Eagle oil squiter plugs
    ARP Head Studs
    Update 10/21/2010
    P72-1 head with
    It's in the shop when i get it back i will post pic's.
    ITR Cams
    CROWER CHROMOLY RETAINERS
    BLOX DUAL VALVE SPRINGS
    Ferrea Flat Face Stainless Steel Velves
    AME Tru Timing Gears 23-602 Blue
  2. bluejcivic
    bluejcivic New Member
    good deal on the crank, have fun building
  3. Taco15
    Tallahassee Fl
    good luck!
    also, any major reason for 10.6.1 compression like power adder later or will you be doing all motor?
    where did you find your pistons?
    I'm in the middle of research so sorry for all the questions.....
  4. LifeSucks88
    Later down the road i am going to put a Jackson Racing Supercharger on it. Now for the piston i got them from here 149219 Product Detail Information - JE Pistons
  5. LifeSucks88
  6. crxpower24
    crxpower24 Member
    are those stock pistons
  7. LifeSucks88
  8. LifeSucks88
    My block is back from the shop
  9. LifeSucks88
  10. LifeSucks88
  11. LifeSucks88
    My head back from the shop
