My Brakes....
1995EGGuy
When I had my stock rotors and brake pads on the brake pedal was fine. When I put my crossed-drilled and slotted rotors with satisfied gransport brake pads on..when i start the car the pedal goes so low and i bled all four brakes really good. The rotors and pads only have like 6000 miles on them. I tried a master cylinder and its not that so thats ruled out. im thinking its the two calipers lemme know what you guys think.
I'd try re bleeding the brakes to make sure and also try replacing the valve thats in the vacuum line that goes to your intake manifold.
Its a check valve, its right behind the cap of your master cylinder
