my civic sounds like its redlining at 3500
Discussion in 'General Tech and Maintenance' started by 1994ex, Jul 18, 2005.
  1. 1994ex
    1994ex Member
    when i step on the gas it can only rev up to 3500 and then it sounds like its redlining. It idles kinda sluggish. What could be the problem? can anyone help?
  2. b16coupe
    b16coupe Senior Member
    anderson, S.C.
    is it throwing a CEL? Timing belt could have jumped a tooth.
  3. 1994ex
    1994ex Member
    i checked the codes and i get code21-variable valve timing and valve lift solenoid, code3and5-check map sensor and circuit
  4. 1994ex
    1994ex Member
    jumped a tooth? how will i know if it did that?
  5. 1994ex
    1994ex Member
    and code 4- check crank angle sensor and circuit. I think i got everything
  6. phyregod
    phyregod !!YTINASNI
    Central Texas
    yeah, sounds like you jumped time. Line up the timing marks on the crank pulley and the cam pulley to their respective spots. (they dont point at eachother)
    If one is on and the other is off, you jumped time. With all those codes I would say that is more than likely what it is.
  7. 1994ex
    1994ex Member
    how can i fix it. can i do it myself?
  8. phyregod
    phyregod !!YTINASNI
    Central Texas
    yeah, you can do it yourself if you have a few tools.. Its pretty simple. But be sure to check the timing belt, make sure it isn't cracking or missing teeth. I would certainly suggest a chilton manual for it, if you dont know for sure what you are doing. You can bend / smash valves working on the timing belt of a honda if you do it just exactly wrong. a $16.00 chilton is cheap insurance.
    If it did jump time, you should also look into finding out WHY it jumped time. Teeth missing on the timing belt is usually the case, but if a rock or a screw or bolt or something got loose inside the timing cover, that would cause it too. Could also be the cam binding. That would be BAAAAD. Be sure to figure out why. That way you arent adjusting the belt every weekend.
