My corn fed Evo 8
Discussion in 'Other Vehicle Discussions' started by B16, Nov 1, 2008.
  1. B16
    B16 Super Moderator VIP
    yay area, CA
    So here in the bay area we just started receiving E85 at our pumps. Holy crap this is great fuel for boosted cars. Take a look at the difference between using the two fuels 91 vs E85. I don't think I'm ever going back to 91 now. :)
    My scanner isn't hooked up, so I had to take pictures of the dyno graphs. :)
    On 91 it made 262whp/259wtq @ 23psi
    on E85 it made 333whp/318wtq @ 27psi
    +71whp/+59wtq
    Mods:
    2005 Evo GSR
    TBE no cat
    RC 1000cc injectors
    Walboro fuel pump
    GM 3 port
    The car is an animal now. I don't think I'll ever got back to 91 unless I'm forced to.
  2. |Chaz|
    |Chaz| Well-Known Member VIP
    Wow, that's a huge difference.
  3. TurboMirage
    i want to convert my 1.5 to run e85 since mitsubishi motors run so fucking well on it, but alas there are no pumps within 60 miles.
  4. B16
    yay area, CA
    I think boosted motors see the largest benefit. Its like running 110 octane!
  5. BodyDroppedNikes
    caught in a mosh...
    i did not know that the EVO 8 was a flex fuel vehicle :huh:
  6. phyregod
    phyregod !!YTINASNI
    Central Texas
    Well, E85 and 5 more pounds of boost, lol.
    But 333hp @ 27psi? Doens't that seem a touch low for that kind of boost? Am I crazy?
  7. austin20110
    austin20110 New Member
    Northern Va
    I was thinking the same thing lol
  8. Matts96HB
    Matts96HB . Moderator VIP
    For the stock turbo, no.
  9. reikoshea
    Dallas, TX
    you also have to remember evo's lose a lot of whp in the drivetrain. awd != whp
  10. B16
    yay area, CA
    You can make any car flex fuel with larger injectors and tuning. :)
    This was done on a Mustang dyno. Probably more like 370whp on a dynojet. These dyno's read very low. Stock Evo 8's baseline at around 225whp on this dyno. Thats why you should really be comparing the difference between the 91 tune and E85 tune. :D
  11. Briansol
    yeha, would've liked to see the 23psi vs 23psi pull
  12. B16
    yay area, CA
    The point of E85 is the ability to run more boost safely. :) You can also lean it out much more, which would have given some gains on 23 vs 23 psi I suppose.
  13. JDM-GOLDEK9
    JDM-GOLDEK9 New Member
    Canon City, CO
    that is amazing. but can you just put e85 in or does it need to be a specific engine, or do you need any special mods for this to work?
  14. B16
    yay area, CA
    You just need larger fuel injectors to deliver more fuel, and the ability to modify fuel and timing in the ECU. I don't think it would do much for our Hondas, unless we're boosted or running very high CR.
  15. JDM-GOLDEK9
    Canon City, CO
    well i'm building a boosted ls vtec. and trying to make it the best i can e85 sounds pretty good
  16. B16
    yay area, CA
    Yup, seems like the holy grail for fuel on boosted cars. Very high knock index and the ethanol has exceptional cooling properties. You're in CO, I think you have many E85 stations around. Go for it!
  17. JDM-GOLDEK9
    Canon City, CO
    nice thanks for the info you think 40mm injectors will cover it?
  18. B16
    yay area, CA
    40mm?? I'm not familiar with measuring injectors in mm.
  19. JDM-GOLDEK9
    Canon City, CO
    sorry i meant 400 cc lol cause 330 cc is 40 psi *noob typo* :D
  20. JDM-GOLDEK9
    Canon City, CO
    i just calculated it and if i boost the ls out to about 330 whp then i would need 600 cc injectors for optimal flow.....damn.....those should cover e85 lol
