My Crx Pics
Discussion in 'Auto Multi-Media' started by dilbeckskate, Dec 28, 2010.
  1. dilbeckskate
    dilbeckskate infamous
    Kennesaw Ga
    Heres some pics of my CRX, got the traction bars all bolted up now, cant wait for the snow to melt to try them out
  2. 95b16coupe
    95b16coupe New Member
    ct
    should be in "auto multimedia"
    you're really trying to get your rep back arent' you? lol
  3. dilbeckskate
    Kennesaw Ga
    ha well will sombody please move it ? i opologise, I just quickly posted the picks after I re-sized them and wasnt paying attention
  4. 95b16coupe
    ct
    it's ok. we won't neg rep you for a while. lol hell, i can't even give you the positive rep i owe you because i have to spread it around first. remind me, i'll get back to you.
  5. E_SolSi
    moving AGAIN!!!
    ill get rid of the other thread for you too
    :moved:
  6. Ethan
    Ethan Well-Known Member
  7. dilbeckskate
    Kennesaw Ga
    Appreciate it
  8. 92stoccord
    92stoccord Big Member VIP
    Salem, Ohio
    Is that a legit CTR shift knob or is it just an ebay one?
  9. dilbeckskate
    Kennesaw Ga
    idk its one my buddy gave me, it might be legit or it might not be, lol im guessing a fake
  10. 92stoccord
    Salem, Ohio
    Did they actually come with a panel covering the fuse box or did they leave that open, cause mine doesn't have it either, and I figured it was just tossed.
  11. brian11to1
    brian11to1 Senior Member
    hahahahhhaa
    Why do you have a one way check valve on that tube? Whats up with the foam padding on the fuel rail?
    stock b16?
  12. dilbeckskate
    Kennesaw Ga
    ha I actually broke it :(
  13. dilbeckskate
    Kennesaw Ga
    Ha I had 2 peices of hose and needed to join them together to make it long enough haha figured it couldnt hurt, and idk I was actually experimenting with the foam, thought it made my engine bay look better dull'd down a little, and its a factory b16a with a port and polished head, and a gsr tranny and fuel rail/injectors, nuttin special, its fun though
  14. Taco15
    Tallahassee Fl
    looking good.
    be careful with some of that rust you have on the shock. try to keep them lubed at least.
    how do you like the traction bars?
  15. brian11to1
    Ahh... vac. line or whatever is like $1/ft and would look a lil better. As far as the foam... :rolleyes: looks completely out of place! I'm all for experimenting though
  16. DESPAIN
    flower mound TX
    Nice crx............. Simple and clean.........
  17. dilbeckskate
    Kennesaw Ga
    Ha I lubed them yesterday, the traction bars really just make my suspension feel stiffer, it will still spin the piss outa them, but u dnt feel the car spinning at all, appreciate everything guys
  18. brian11to1
    Not sure if it crossed your mind, but if I were you (and if you haven't already) i'd pull the radius rods out, pull the heim joints and apply copius amounts of anti-seize to them. If yours are anything like my Full-Race ones, the joints and rods aren't coated and will seize at the first sign of moisture!
