my dad is irritating me lately...
Discussion in 'General Tech and Maintenance' started by hatukazi, Jan 2, 2009.
  1. hatukazi
    hatukazi ambitious...but rubbish
    Big Lake, MN
    ..., not because he hasn't helped me, he has.
    anyway I replaced my clutch cable yesterday, car shifts like new now.
    the clutch felt wasted, now works as normal as a cx clutch on a Z6 can.
    then my dad "do you know why your clutch cable stretches?"
    "no"
    "it's because your grounds are going bad and when your clutch cable becomes the new ground, it heats up and stretches"
    "fucking ridiculous, the clutch cable is plastic shielded:confused:, how would that be?"
    well, I had a miss I could'nt cure for a couple of months now, it's gone.
    and my amp was cutting out when I drove over bumps, not anymore:confused:.
    so now I get to be frustrated by my car running right?
    I'm going to test my grounds for resistance later...
  2. INJEN78
    INJEN78 HS LEGEND
    OHIO
    go on ebay get a ground wire kit,and hook that up
    its like 7 or something grounds
  3. hatukazi
    Big Lake, MN
    rockford fosgate 4 guage
    and my original ground was 5 ohms resistance, fosgate wire .5 ohms, much better
  4. dacheat
    dacheat ..is grounded.
    strongbadia
    i think injen means the kit has 7 different ground wire connex in it. :shrug:
    1 person likes this.
  5. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    And Hatuzaki is saying he already has 4ga wire he could use?
  6. TurboMirage
    im using the ralli///art ground kit on my mirage. i dont think it helps any. the big cam gives me a rough idle that cannot be smoothed out.
  7. YBLEGAL
    YBLEGAL Regular Member w/ Cheese
    NW Indiana
    Tell him the clutch cable stretches because it's like a bicycle...
    Metal can stretch; believe it or not! haha
    4 guage fosgate here. tests literally 0 ohms.
  8. phyregod
    phyregod !!YTINASNI
    Central Texas
    It will stretch if it is adjusted wrong. But it has nothing to do with grounding and heat.
  9. INJEN78
    INJEN78 HS LEGEND
    OHIO
    correct
    well duh,the big cam cant be smoothed out,but the ground does help wit electrical stuff
  10. hatukazi
    Big Lake, MN
    that sounded really sci-fi to me, I figured just because it's old.
  11. hatukazi
    Big Lake, MN
    like the NRG kit my friend has on my old rex, they are pretty cool but saving for a clutch/flywheel set.
    correct, and already terminated except for the post connector, so altogether only cost me $8:)
