My display and rear lights wont light up for 92 hona prelude si
ssquires852
for my 92 Honda Prelude Si the display back light or the lights for the rear side of my car dont turn on, my head lights do, but nothing else, I checked all fuses, and not sure if its a lose wire somewhere, or where it would even be. Anyone have any good suggestions, diagrams or anything to check out???
Spencer Squires
734-790-5065
the rear lights and dash lights are on the same fuse under the dash. check that fuse again. there should be a diagram showing which fuse it is. if its not that fuse, then there is a short somewhere in that circuit. good luck.
if not go buy a computer from autozone find the code fix it and then return the compouter to autozone for a refund.
