my engine build what you guys think?
Discussion in 'Engine Building' started by Kolumbo69, Dec 2, 2004.
  1. Kolumbo69
    Kolumbo69 Senior Member
    Calgary canada
    B16- sleeved to 84mm new gaskets etc
    1.7L rods and crank
    shot peened rods with arp rod bolts
    itr cams
    uberdata tuning
    11.8:1 arias pistons
    not sure on header, custom exhaust
    I thinks thats it, ill be putting it in a civic 88-91 lx 4dr
  2. phunky.buddha
    Dallas / Fort Worth, TX
    Sure. :thumbsup:
    1804cc with a 1.62:1 rod/stroke ratio should be pretty good.
  3. Kolumbo69
    Calgary canada
    Thanks something to do with all my extras from my rex, and i cant afford to rebuild my ae86 lol. Im hoping 180 whp maybe a bit more not sure if its attainable
    Oh yah i also have a 10lbs flywheel an ill use a cable lsd tranny
  4. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    try getting the rods cryo treaded it worked for me
  5. Kolumbo69
    Calgary canada
    i actually never thought of that. It been a while since i have been with the honda shit drifting makes you go crazy!
  6. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    for the transmission i recommend one from a b17 integra or JDM 92-93 Integra XSi/RSi, the jdm one has optional lsd i think.
  7. phunky.buddha
    180whp is doable on that setup with decent tuning.
  8. sohcslammer
    sohcslammer Senior Member
    Bay Area
    Ditch the ITR cams. Go with something MUCH bigger for that setup. Otherwise... :thumbsup:
  9. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    FoDo's are the bomb diggity, y0!
  10. Kolumbo69
    Calgary canada
    only using the itr's cause i already have all this stuff in my garage collecting dust
  11. civicious
    Houston, TX
    Then what are you waiting for? Get off the net and slap that shit together, y0!
  12. sohcslammer
    Bay Area
    Sell them to someone for $300. Pick up the Comp/zex 57200 for $400. Net 10 HP. It's your car.... :shrug2:
    I believe Brian (pissedoffsol) has a hook up on buddy club stuff. I know the buddy club cams are good for 15 whp OVER the CTR cams...
  13. K2e2vin
    Raleigh, NC
    the buddy club spec III+ cost $500 from kteller, pretty good price(isnt that like as much or cheaper then skunk camshafts?)
  14. beerbongskickass
    beerbongskickass Senior Member
    Longview WA
    Your forgot to add the turbo...
  15. Kolumbo69
    Calgary canada
    i think my 11.8:1 compression would make any engine go booom
    i havent started cause i need to find a four door. need money for sleeving
  16. civicious
    Houston, TX
    ?? Try 12.6:1 y0
  17. Kolumbo69
    Calgary canada
    i ment for putting a turbo on lol oops didnt explain my self
