xj0hnx I wanna be sedated VIP Mar 20, 2003 #21 You see your air intake?that goes to the throttle body and that is bolted to your intake manifold.There is a white sensor on the front.
R rsaeini Senior Member Mar 21, 2003 #22 Thanks. I think I got it. I just need to wire that into the ECU and and everything should be running perfectly.
R rsaeini Senior Member Mar 22, 2003 #23 Sorry people, I'm just so excited that the motor is in and it's running ok. check out the pic. don't forget to check out my Vision corners... it's alive...it's really alive....hahahahahahahaha
