My engine
Discussion in 'HYBRID -> EG-EK / DC' started by civicracer901, Dec 22, 2002.
  1. civicracer901
    civicracer901 Senior Member
    Clearwater,FL.
    When I press the gas pedal to the floor to get on it. The engine stubbles on acceleration. Thought someone could give me some things to check out. Here is a exsample..
    I went to lutz Friday, I went to step on it but the engine would kinda jerk back a little bit. It wouldnt hold back just jerk around alittle bit. It did it through Its fine on normal driving but when I step on it , it jerks. Can someone help me please.
  2. junior3478
    junior3478 Junior Member
    Daytona Beach, Florida
    hey could be a fuel problem..maybe fuel filter, fuel pump, injectors, fuel rail isnt workin properly when the motor asks for more gas..FUEL?
  3. civicracer901
    Clearwater,FL.
    its a mugen chipped pr3 or you mean the fuel rail? cause i think that is stock. Thing is though it use to be fine now all of a sudden its doing this.werd.
  4. HenryOng074
    HenryOng074 Member
    its your fuel system. check injectors, fuel filter, fuel pump
  5. 2 litre EG
    2 litre EG Senior Member
    so cali
    i could be fuel but one simple mistake it could be is distributor might be loose... i've seen that occur before, check to make sure your distributor is on tight
  6. knowledge
    knowledge Senior Member
    Beale AFB, CA
    I had that problem over the summer. Do a full tune up! Plugs, wires, distributor, rotor, fuel filter. Solved my problem. But actually the wires, plugs and distributor cap fixed my problem. But do a full tune up!
  7. civicracer901
    Clearwater,FL.
