my first buld
Discussion in 'Civic and del Sol - EG and EK' started by frodotoolbox, Jan 8, 2009.
  1. frodotoolbox
    frodotoolbox 92 civic si d15b
    sc
    my first build
    ok so my d16z6 in my del sol got hydro locked a while back.
    the del sol is getting a f22.
    and i want to build my z6 and possibly put it in an eg.
    first question:
    since the rod was bent it kinda f-ed up the sleeve.
    so since it needs to come out i was thinking bore out the block... would it be better to just re-sleeve it or would a bore be good. i am planning on turbocharging it and using it as a dd.
    thanks,
    jamie
  2. austin20110
    austin20110 New Member
    Northern Va
    Umm its build not buld.
    Anything over 350 you want to sleeve it.. like we have discussed 1000 times.
    Anything over 250 you want to forge it...
  3. frodotoolbox
    sc
    sorry must have missed the "I"
    this is the first time i have even thought about boring out my block.
  4. frodotoolbox
    sc
    now i ran into a road block with my del sol swap.
    i cannot find wire diagrams for neither the del sol nor the accord so i cannot rewire the ecu.
    does anyone know where i cn get the diagrams????
  5. BrutalB83
    Rochester Hills, MI
    What do you mean by "rewire the ECU"? I'd probably use a chipped Civic ECU...that should make things easy...
  6. frodotoolbox
    sc
    i have the ecu from the accord for the f22 but do i not have to wire it for all the lights and gauges????
  7. jdmrex08
    jdmrex08 New Member
    use one for electronics, lights, gauge, dash, etc. and use the f22 ecu for your engine
  8. frodotoolbox
    sc
    use one what???
    switch??
