efhondakid
My name is Byron.
Yep you do need to make a dent for alternator pulley clearance, but you shouldn't need to cut or weld anything.
You need...
-Engine/trans/ecu of choice
-90-93 Integra axles
-90-93 integra 5speed intermediate shaft
-rywire jumper harness
-90-93 throttle cable
-shift linkage (hasport, innovative, avid, ebay)
-motor mounts (hasport, innovative,avid,ebay)
-cable tranny speed sensor
-90-93 integra drivers side engine bracket (94+ engine brackets won't work)
-90-93 integra rear transmission bracket, must be from a manual
You'll need to solder the 5 wires going into your resistor box. There should be 4 red and one yellow, solder them all together, and remove the resistor box.
You'll need to move/extend the fan switch connection from the back of the block to the side of the head.
The maf on your crx is firewall mounted. On your new engine it will be on the top of the throttle body. just unplug the 3 pin connector from the firewall, and move it to the tb.
And you will also want to remove the dust seals within your hubs to make clearance for your axles, otherwise they may bind up.
http://img48.imageshack.us/img48/29/97846269fd0.jpg
If your car is lowered you will need a ctr crank pulley (aka: crank pulley with just the ribs for the alternator), or have your b-series crank pulley's a/c and p/s ribs machined off. otherwise your crank will bottom out on the traction bar making right turns, and make a nasty grinding noise.
That should just about do it i think
Hey, see what a little bit of research turns up? All that is correct, altough Ive never heard of having the crank pulley hit the traction bar.
