My first Honda!
Discussion in 'Civic and CRX - EF' started by DirtySprites, Feb 21, 2015.
  1. DirtySprites
    DirtySprites New Member
    Woohoo
    Ok so like it says my
    First Honda I traded my 1988 Dodge Raider for a 91 hatch D15b2 120k and how you see it (minus the hole in the block) is how I got it. image.jpg
    I saw potential so I took her home from Knoxvile TN back to Blue Ridge GA image.jpg image.jpg image.jpg
    image.jpg Well like I said I blew it up the day I got it legal pulling away from the gas station so now I have this..trans is good and so is the top end may use it for a project motor image.jpg
    So I saved up a little cash and went shopping and eventually found what I think is a good deal after looking at swap choices image.jpg image.jpg D16Z6 with a 5spd and ECU from a DelSol odometer had 204k on it
    I paid $450 for everything
    im in the process of cleaning out my bay and pulling all those horrid loose wires and that ugly tach hanging there haha!
    I know I need to swap to OBD1 and I think if I understand I need to swap from DPFI to MPFI, and do the VTEC wire up right I've read some other threads just trying to cover all my bases and I will keep updating with pics and all as the build continues.
  2. DirtySprites
    Al does anyone know where to find one of these for a 91 hatch I want to layout some ideas for paint and body stuff for down the road
  3. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    i know to each his own and all, but man to be honest those cars are a dime a dozen here in the south, you can get one with an almost perfect body for no more than a grand that has a bad engine and one that has a good one for not much more than that, instead of dumping a boat load into that one id just try and get another body.
    Jeef likes this.
  4. DirtySprites
    I was looking for a project that I could also drive while fixing up dont really have a whole lot in it but the stuff mentioned above that I purchased plus pretty sure the wife won't let me buy another car ha
  5. Jeef
    Jeef NO MA'AM Moderator VIP
    Good luck seems like you are in the right direction but that car is rough. I hope its not a money pit for you.
  6. DirtySprites
    Me too if it looks too bad when I get into it I'll find a new body but I'm hopeful so far is there a spot I can buy the harnes swap over
  7. get_nick
    Washington State
    Man, that's going to be a serious project. There isn't much going well for that car. good luck man.
  8. whiterabbit06
    Crestview, Fl
    +1
    Good luck!
  9. AHHVTEC
    Alabama
  10. Jeef
    Damn those are cheap. I have been looking for a cheap beater and I can't find a civic for under 2k
  11. get_nick
    Washington State
    Yeah, I would probably scrap that hatch or use it for insurance fraud (#notserious) It might be good for some bolts and clips, but 90% of that car is trash.
  12. Briansol
    put mudders on it and take it in the woods :D
    efhondakid likes this.
  13. Jeef
    Just looked back at the pics, the body and interior are going to kill you. I hope you know how to do body work, I would also check the frame since it looks like it has been hit.
  14. efhondakid
    Akron-Canton, Ohio
    Seeing them that cheap and rust free really has me thinking I need to get down south with the truck an trailer. Would really like to build another B swapped EF was a fun little car.
    As said before the body work is going to kill you if you plan on "restoring" it. Either way it is a project and will be a good way to learn some new shit.
  15. AHHVTEC
    Alabama
    yeah there are tons and tons down here, even si, and crx. that was just a fast search close to his location.
  16. DirtySprites
    Wow I need to learn to reuse craigslist I might be picking up the black one I'm calling in the am
  17. whiterabbit06
    Crestview, Fl
    What he said!
    Briansol likes this.
  18. DirtySprites
    Wish the guy with the shell would answer haha I really need him to now I was removing the body kit from the car and a block of wood fell from in between the fender and side skirt.... Smh well live and learn image.jpg
  19. Briansol
    home depot special hack job
  20. get_nick
    Washington State
    Did you buy this car from a guy named "dickskate"?
    CAFROG and BrutalB83 like this.
