Originally posted by GSRCRXsi@Sep 29 2003, 11:36 AM
very nice, looks really clean. whats the maximum psi you can push with the 3 bar map? 1 bar is like 14 something right? so should you be able to push 42psi?(assuming you were built to handle it of course)
Originally posted by SolReaver@Sep 29 2003, 03:09 PM
colorpros- very clean install. well done
now, as far as stock honda map sensors, this is what they "read"
OBD0 .65 KG/cm2= 9.24 PSI
OBD1-2 .75 kg/cm2 = 10.66 PSI
With the GM 3 bar, up to 29 psi can be read
3 bar= 44 psi
44- 14.6666= ~29 psi
Originally posted by GSRCRXsi@Sep 29 2003, 08:08 PM
why did you subtract the 14.666666? if its a 3 bar map sensor, shouldnt it read 3 bars? ie 44psi? im confused, someone explain.
Originally posted by SolReaver+Sep 29 2003, 11:06 PM-->GSRCRXsi@Sep 29 2003, 08:08 PM
atmospheric pressure y0!!!!!
we are in 14.6 psi now, the map sensor reads as long as you are on earth
