Poweredbyrcade
For some time now my 93 gsr has been feeling really sluggish and slow. What happens is that when I drive the car cold usually it feels normal and can burn rubber at times whithout trying but when the engine gets hot it starts to feel sluggish. The RPM stays at around 500 or 200 and when I get off a red light the car feels like Im starting in second gear. Sometimes even the car feels like its being held back and then all of a sudden its let loose and you feel a slight power increase.
I don't know what could be wrong I thought it was the fuel pressure since I discovered that it was a couple of psi below the recommended specs but I adjusted it since the motor has an adjustable fuel pressure regulator and its up to specs now however the problem still persists. If anyone can help I would really appreciate it
