My LS swapped EJ2 w/ pics
UNDR8D
...has a job!
Hey everyone. Just wanted to toss up some pics of the EJ. Still a long way to go. Let me know what you think. I can handle criticism :cool:
Engine after first getting it in the car
Teg radiator, slim fan, horrible OBX valve cover
Home-made intake, header, and horrible OBX valve cover again, it gets better though...
Live Free or DIE!!! (I do not live where this plate is registered so don't show up in NH trying to steal my car...)
Stealthy exhaust (I just reaized I have way too much Password:JDM shit on this car!)
I apologize for the Acura emblem...I did it on a whim and it has since been removed
Antenna block-off
Muuuuch better...
Mirror block-off
It's a terrible picture but here's the truck I built. My pride and joy for 6 years. I recently sold it to pay off credit card debt. I actually cried when the guy drove it away.
This was the second rear setup I built for it. I fabbed everything including link bars and tabs. Truly my finest work.
Well, there it is. I'm shooting for clean JDM. Not quite there yet. I ran out of money...
Looks nice. I'm not to into the mini truck thing, but I guess it's cool that you fabbed everything yourself, I can appreciate that part. :thumbsup:
I just lowered it another inch. No change in ride and it looks a lot better. I was surprised.
hey not to be a noob or anything but what did you use to make that header?
I'm pretty sure that's just his exhaust manifold, or a header he got, and wrapped it in heat-wrap. I don't think he fabbed his own header.
Looks good. :thumbsup:
BTW, I've heard "heat wrapping" your intake does more harm then good, supposedly the heat gets trapped in there. But I just read that somewhere, I don't know the validity of it though,
Sorry. I figured there would be some confusion over my chosen phrasing. It is not a homemade header, although, I'm sure I could pull it off. My exhaust however I did make. It was such a mistake. It is 2 1/4" and it sounds great but all those pie cuts and welding...I did it to save $400 but in the future, I will just buy an exhaust. As far as wrapping the intake, common sense and what little I know of thermodynamics tells me that the intake metal absorbs underhood heat so shielding it from that heat would keep it cooler. I didn't do any research though. I just see a lot of turbo cars with wrapped charge piping and I just applied the same principles. Obviously my underhood temps aren't anything like a turbo cars are but still, any little bit helps...
Just how much work was it to get the Teg radiator to mount up?
I cut the lower mounts off and flipped them upside down and welded them underneath the pinch joint that they are normally on top of. I connected the hoses so I knew they would fit and they helped to hold it in place while I centered it and fitted everything. It was not much work at all. A little snip snip. Nothing drastic. It runs so cool too. I took it on a 12 hour (one way) road trip last weekend and did 85-90 the whole way and between highway and stand still traffic, it barely made it above 1/3 on the temp gauge. I have a second slim fan I am going to install on the outside of the radiator when it gets hot out...
