ls/vtechatch91
okay.. so i had ls/vtec back in september.. drivin along and my car dies completely... later to find out my timing belt had 5 inches of teeth missing... which sucked.. so took off the head found out it had bent valves and put back on a ls head.. anyways... now im going to do a mild build on my other b16 head... port n polish.. GSR cams. type r valve springs and omni flat valves... my bottom end has jdm pr3 pistons.. all new oem gaskets and bearings... arp rod and main bolts.. stage 1 clutch with a 7.5 flywheel... the bottom end hasnt even seen 4k miles... anyways ill post pics up tomorrow of the valve springs, car, motor, and head... let me know what u guys think so far...
