i did a little bit of research and couldn't really find anything on this particular topic so here we go.
i have a B16A2 and it's getting outfitted with the following:
-CTR pistons (standard bore)
-Skunk2 Stage 2 cams
-portflow dual valve springs and retainers
-2 layer head gasket
there are a lot of other things going in but my major issue is the clearance.
my question is about the piston-valve clearance.
will it be ok?
OR
am i pushing the envelope?
UPDATE: i can't decide which route to take.
i was planning on doing the above but one of my friends gave me a really smart idea. he said instead of building that B16 bottom end i should replace it with a B18C1 and basically make a homemade ITR but with one small difference...Skunk2 cams.
i've been going back and forth on this for about about 2 weeks now. i don't know which one to do.
the B18 will give me more power and more important...more torque. <---a must in road racing but it will cost me about an extra $1000
but the B16 will be a lot cheaper of a build since i have everything except for the CTR pistons. it will only cost me about $200.
WHAT SHOULD I DO???
will it be ok?
OR
WHAT SHOULD I DO???
