My new 2010 Subaru WRX
Discussion in 'Other Vehicle Discussions' started by GSRCRXsi, Feb 5, 2010.
  1. Matts96HB
    Matts96HB . Moderator VIP
    Ian, how are these things when they're stock? I'm looking for a new DD. Reliability is my main concern.
  2. GSRCRXsi
    MD
    They are pretty reliable if you leave it stock and don't abuse it and keep up with maintenance items.
    What year are you looking for?
  3. Matts96HB
    I really like the body style you have to be honest. 2010-2012 ish?
  4. GSRCRXsi
    MD
    Mine would be 2008-2010.
    The 2011-2014 is the same chassis but wide body fenders
    If I were to do it again I'd get the 2011
    Matts96HB likes this.
  5. awptickes
    MD
    You should have knocked on the door, announced yourself loudly, then I would have given you some pants. We could have had a beer. Jerk.
  6. Matts96HB
    I do like the wide fenders. Thanks for the advice man!
  7. Briansol
    a co worker just got a 2016 wrx. the twin scroll is super fast. like part throttle normal driving is boosting 5+ psi.
    the interior is a LOT nicer than my 05 sti was, that's for sure.
    he's still only getting 22 mpg out of it though mixed use, not really beating on it, and that's just a deal breaker for me these days, especially when it requires 93.
    28+ on 87 (even if it pulled timing) and i'd consider one...
  8. jeffie7
    jeffie7 Wrong Whole! VIP
    Maryland
    Near stock... needs a tune. I don't trust a stock WRX or STI tune. Do intake/exhaust/tune and call it a day.
    I still like my 05 I think its cool that the WRX is getting nicer, but I wish they stripped the STI down. I like the original ones with no bells or whistles.
    double0Si likes this.
  9. TurboMirage
    I put 91 in the VT and get 28+
  10. Matts96HB
    I forgot you have one of these. I'd go for a hawk eye if I can find one that has been treated decently. What's insurance like on these things?
  11. Jeef
    Jeef NO MA'AM Moderator VIP
    How are they in the snow, guessing a snow tire will be needed?
  12. TurboMirage
    Snow tires should be required on anything in a place that gets more than 2-3 inches of snow a season.
    You live up here I'm surprised you ask that question.
    Briansol likes this.
  13. jeffie7
    Maryland
    Blob eye ftw!
    Insurance? Not really sure. Don't look at the breakdown between the different cars.
  14. Jeef
    I never ran a true snow tire on anything other than my current 2wd truck. I have always gotten around with a good set of all season tires. The WRXs I have seen have had a more aggressive tire on them.
  15. TurboMirage
    A full set of snows works wonders on anything. They aren't just for bad weather the compound gives you good grip in the cold/ freezing temps too where an all season may get a little hard.
  16. Briansol
    when your car comes with SUMMER tires, it really makes no sense to buy ALL SEASONS as a winter tire...
    TurboMirage likes this.
  17. GSRCRXsi
    MD
    Another mass update.
    Sept. 2016 - 193k, Got a 60k service @ IAG minus trans and rear diff fluids as I was scheduling a trans swap soon, why waste the fluid.
    Oct. 2016 - replaced my KillerB alternator cover because it broke again, for the 3rd time. I'm tired of dealing with it, replaced it with a Grimmspeed unit that wont break.
    Oct. 2016 - did a full brake tune up. new rotors and pads all around. went with KNS 4k brake rotors, HPS 5.0 front pads, and StopTech Sport rear pads.
    Oct. 2016 - STi 6-speed transmission swap:
    I've been collecting parts for the past year or so in preparation for the swap. I had initially planned to do a built 5-speed + DCCD, and i even bought a 5-speed DCCD trans with a busted gear with the intent of harvesting the DCCD unit to use on my trans with a build. After a lot of thought and back and forth, I decided to abandon my 5 speed DCCD vision. The STi swap would cost about the same, even though requiring more parts to be replaced and a little more work. and the STi trans stock is still stronger than a built 5 speed. I also planned to do the swap myself, and I'm certainly capable, but after struggling with awptikes to do the transmissions in his trucks, and the associated issues with jacking my car high enough to get the trans out/in, AND wiring up the DCCD (i hate wiring), I just decided to pay IAG to do it. they have better tools, better techs, and they can crank it out faster and do the wiring and i KNOW it'll be right when finished. I bought the trans/diff/slave together. i looked for deals where i could. Bought the parts needed for about $5k and the install was about $1500 in labor.
    Parts used/needed:
    2011 STi transmission - used
    2011 STi R180 rear diff - used
    2011 STi clutch slave cylinder - used
    2011 STi shift linkages
    08-14 STi rear diff brace - used
    08-14 STi driveshaft - used
    08-14 rear axles - used
    6-speed transmission mount (group N) - new
    Kartboy 6-speed short shifter - used
    Kartboy 6-speed front shifter bushing - new
    Turn-in Concepts shifter pivot bushings - new
    Southbend "Stage 2 Daily" clutch kit for STi (495 ftlbs) - new
    OEM Sti flywheel - new
    DCCDPro DCCD controller - new
    WC Lathe Werks shift knob - new
    The guys at IAG said my install went about as smooth as could be, and that the swap i gave them was complete with all parts in good condition.
    After the install, I had them perform an alignment on the car (some suspension components removed during install, and the 6-speed is like 75lbs heavier than my stock 5speed). The tune on my car also needed to be tweaked to account for the different gear ratios. I was surprised that it needed it, but the tuner said my car had lost 5-6lb boost from the trans swap. after the tune touch up, the dyno plots show almost the exact same HP/tq vales as my car made 1.5 years ago, so it's good to see that the car is still running great with no loss in power from wearing out or anything like that. the engine has about 95,000mi on it since IAG rebuilt it.
    car put down 308/372 @ 21lbs boost, ~74F with the stock vf52 (which is now the oldest drivetrain component on my car with 197,000miles on it!)
    previous dyno run was 315/381 @ 21lbs boost, but ~48F. the profiles match and the two graphs nearly lay on top of each other.
    The new trans shifts great and the clutch feels awesome. no more clutch chatter, and no more heavy clutch pedal. the car is more enjoyable to drive for sure. and i can feel the handling difference from now having front and rear LSDs + DCCD. looking forward to playing with this in the snow :)
    Matts96HB, Briansol and TurboMirage like this.
  18. GSRCRXsi
    MD
    Forgot to post the dyno sheet.
    Two pulls 1.5yrs apart. (The recent pull was started at a lower RPM)
    TurboMirage and Briansol like this.
  19. GSRCRXsi
    MD
    Here's the gear ratio comparison.
    Blue is the old 5 speed
    Orange is the new 6 speed
    assumptions:
    245/40/17 tires
    6500 rpm rev limit/shift point
  20. Briansol
    what's with the line lengths? why does 5th/6th on the respective tranny's drop below 4th/5th ?
