My New Swap
Discussion in 'HYBRID -> ED-EF / DA' started by obd1 kenobi, May 11, 2003.
  1. obd1 kenobi
    obd1 kenobi Junior Member
    Vancouver BC Canada
    [​IMG] Videos: [​IMG] Other images
    Click on image for engine bay close-up.
  2. Slo86GT
    Slo86GT Super Moderator
    Memphis - Hellhole of the South
    Car and swap looks clean...
    You video's are WEAK. ;)
    It's called burnout... where's the SMOKE?!? :blink:
  3. kyleirwin
    kyleirwin Retired OG
    Vegas
    :werd: ...and that's puttin' it nicely.
    you call that a burnout? :lol:
  4. obd1 kenobi
    Vancouver BC Canada
    I have very crappy tires on the car: Michelin XGT4s. With only a bit of battery power left in his digital camera, my brother took three videos. One was buggered. He named the files. I never renamed them. Though, the night before, when I unveiled the swap in Penticton, BC, I had a much better burnout. It was not recorded. Probably lost a bunch of rubber and could smell the clutch a bit.
    But, anyway, thanks for the compliment on the car and swap.
  5. phunky.buddha
    Dallas / Fort Worth, TX
    Very nice, very clean. The valve cover paint job looks damn good too! :thumbsup:
  6. whiteboyscivic
    whiteboyscivic Junior Member
    hey so does the vtec work with block? and do you recommend this swap ?
  7. Gen2Teg
    Gen2Teg Senior Member
    san francisco
    :readfaq:
  8. obd1 kenobi
    Vancouver BC Canada
    It most certainly does work and I highly recommend the swap. Just don't rev over about 7200 rpm, which is out of the peak power and torque band anyway, and you'll be fine with the approximately 1.539:1 rod ratio. Of course, if you choose to build the bottom end, disregard the 7200 safety barrier.
  9. phunky.buddha
    I assume you're using the stock bottom end setup? Your rod/stroke ratio should be 1.539, not 1.49.
  10. THiroshima83
    THiroshima83 Member
    what is your set up internally on that thing?
  11. obd1 kenobi
    Vancouver BC Canada
    B20B block is completely stock internally except for the intake valve reliefs on the pistons. They're enlarged. The B16A head is completely rebuilt, with ITR valve springs, porting & polishing and a 3-angle valve grind.
