my new wheels
Discussion in 'Wheels / Suspension / Tires / Brakes' started by sportlinecrx, Dec 21, 2002.
  1. sportlinecrx
    sportlinecrx Banned
    rage 5.0's (made by konig for americas tire) 14x6's with 185/60's. they look even nicer than i thought they would. :)
    here's a before pic
  2. Jeef
    Jeef NO MA'AM Moderator VIP
    Definetly looks better than the black steelies.
  3. zueke
    zueke Senior Member
    Lansing, MI, USA, Earth...
    Congratz man for the nice look! :)
  4. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    Are those JDM tails on that?
    Wheels looking good
  5. pissedoffsol
    cool- but why didn't you go 15x7's? :)
  6. djextremity
    djextremity Senior Member
    in your rearview mirror..wait..
    Lookin' good, now all you need is a B-series :D
  7. sportlinecrx
    sportlinecrx Banned
    thanks u guys!! yea, all i need is a b16 :)
    i didnt get 15"s cause they stick out of the wells...which i think looks ghetto. the 14"s fill my wells perfectly and are just 11lbs each.
    regarding the taillights: they're plain old usdm. the "cr-x" and other markings are custom. i made them myself. i will be making the hondaswap.com stickers for the site too.
  8. knowledge
    knowledge Senior Member
    Beale AFB, CA
    Bro I got 17's and they sit flush with my wheel wells! Its all about your offset yo!
  9. kyleirwin
    kyleirwin Retired OG
    Vegas
    like knowledge said... it's all about the offset y0! and your 14" smay be a couple pounds lighter than the comparable 15"s, but that extra inch of sidewall probably weighs just as much if not more as an extra inch of wheel.
  10. sportlinecrx
    sportlinecrx Banned
    the 15's are less an inch of sidewall, but they add an inch of tread...and tread is alot heavier than sidewall, so u get heavier tires AND heavier rims.
    there is also the rotational mass equation which basically says a larger rim will require more power to turn than a smaller rim of the same weight. (the rotating mass of a 15" wheel is further from the center/hub than the mass of a 14" wheel)
  11. kyleirwin
    Vegas
    mlm. ouch. :owned: oh well, the 15's still look better :p ... 14" is too small IMO. and the extra tread is a good thing, at least it gives you extra grip. what does the extra sidewall give you??? a better ride??? who cares :)
  12. sportlinecrx
    sportlinecrx Banned
    yes, it's true that 15's would look better, but i only have about 50whp so weight was my biggest concern. the main reason i got alloy wheels was to improve my car's acceleration...and they sure do! :D those are 5lb.s lighter than my steelies. each pound of rotating weight is equivalent to 3.?? pounds of static weight, so 5lb.s x 4 wheels x 3 = the effect of a 60lb. weight reduction :) thats a formula i learned from my mountain biking days.
  13. E_SolSi
    1lb rotational mass = 10lbs static in a car.... you just effectivly dropped 200lbs from your car
  14. cxjon
    cxjon Senior Member
    man+k+toe
    your rex is looking better
  15. sportlinecrx
    sportlinecrx Banned
    damn! :huh: thanks for the info! :D :D :D
    thank u too 92CivicCx! :)
  16. ssbsts
    ssbsts Junior Member
    car looks good. now you just need to lower it.
  17. sportlinecrx
    sportlinecrx Banned
    thanks! and it is lowered. its got eibach sportlines. :)
