My Supra is having Problems
Discussion in 'General Tech and Maintenance' started by MXDesa, Sep 16, 2003.
  1. MXDesa
    MXDesa Senior Member
    Queens, New York
    Hey guys, i've had my 1990 Supra sitting in my yard for about 1 year. I went to start it today and it wont start. I replaced the battery but it still doens't start. I have taken much of a look at it, but i would like some general ideas of what it could be? Anyone?
  2. swanny
    swanny Senior Member
    buck teeth and government checks, PA
    fuel gelled up possibly, make sure you have spark aswell
  3. SleEPeR_CRX
    SleEPeR_CRX Senior Member
    Vancouver B.C. canada
    check ur injectors, and ur tb. they both can get stuck and need coaxing to open, so try out ur injectors make sure they work and make sure the TB is working good. then check ur spark.
  4. MXDesa
    Queens, New York
    Thanks for your ideas guys, ill try those. If anyone has any more ideas, they are appreciated
  5. FFCiv
    FFCiv Senior Member
    is it turbo?
  6. tab
    tab Super Moderator
    Aberdeen, Washington State
    I don't know where you live, but I have seen rats and rodents make nests in the intake, in less than a month. One time overnight.........Just a possibility.
  7. kingwilly
    kingwilly Senior Member
    arizona
    lol...nice pic tab..does it rain alot where you are?when you put your key in the ignition and put it to on but dont start it yet,listen for the fuel pump see if that is turning on,check your wiring and fuses...good luck
