Currently i have a D16Y8 in my crx and came across a cheap Z6 engine that i want to rebuild. It's got 220k miles on it and ran fine. I have been toying with a setup that will give me around 12.3:1 compression ratio using Z6 block, PM3 pistons, Y8 head and gasket. I've never done a build up before but really want to learn. Does this setup sound ok? is compression too high? What types of things will i have to worry about. I can run 93-94 sunoco octane but will this be a good daily driver? For the Y8 head i want to P&P w/possible stage 2 cam. Any suggestions are welcome!
If i need to get the Z6 block bored out at all what kind of pistons shouldi get comparable to PM3. I don't want to spend too much, i'm not going NOS or Turbo so i think i can stay stock but if i bore it out i don't know where to look.
Thanks!
VINCE
Thanks!
VINCE
