although obd0 looks like it only has 2 plugs, the black section is split into two plugs on the wire side. BTW, 92b16vx, the list you just posted contains an error right at the top. the PG7 not the PG6 is for 86-87 teg.
I bought a 91 hatchback si 1st Generastion with a engine swap in it alredy. I Have a 94-95 DOHC Vtec acura GSR ECU Whick is not frm here its a JDM engine and i im tryna work with it.. I Need to find out if itz a mysterious engine which is blocked frm top speed cuz it seems to me that it iz nd if yea how can i unblock it..any info on it iszz alryyte replyy 2 dis POSTAGE Sum1 who noes shyt...
