so how does this work with Sattelite Tv, (direct TV)?
Would I need to have a DTV receiver for each input to the myth TV box?
And since I am a MythTV newb, this would alow me to pause and rewind live tv, while recoring another show at the same time?
thanks
I am considering using ePSXe since it seems to be the most advanced of the emulators. I have a few other options as well.
On the back of your satellite box, there should be a serial port. The Myth backend can interface with this port (and the ports on the back of digital cable boxes) and control it that way. From there you can connect the video/audio connections into the composite/Svideo inputs on the back of your tuner. You'll have to get the scripts and tell Myth that it should control the channels via the satbox instead of the tuner itself.
Myth will allow pausing and rewinding of live tv. It will do this for as many tuners as you have. If you have two tuners, you can watch live TV on one while recording on the other or you can watch both at once with picture-in-picture. If you have three, four or more tuners, the sky's the limit.
You will need a satbox for each tuner, just the same as needing one for each TV. If you don't have enough serial ports to accomodate several satboxes, the Hauppauge (recommended BTW) tuners have IR blasters which can control the satboxes via IR. Just make sure that you seperate the blasters otherwise one will clobber both boxes and screw up your recording.
So if I have an old SAT box and there is no serial port on it, it wont be able to control its interface?
