N/a, Turbo, Or Supercharger?
Discussion in 'Forced Induction' started by dwn2low, Jan 25, 2003.
  1. dwn2low
    dwn2low Senior Member
    Little Rock AR
    Hi,
    I have a b18a1 that I juat bought. I can't decide wether to go N/A, Turbo, or Superchared. I will drive this car daily for now so I don't want to go to Radical. I would like to see from 250-300hp no more since I will not be running on the track that often. I have $1800 at my disposal right now and have more on the way so money is no problem. I have already talked to the machine shop and they are set right now to Port and polish my head, Crowere valves 1mm oversized, Crower springs and retainers. I am putting a 8lb fly wheel in and Have GSR pistons if I want to use them. I am also putting on any edelbrock intake manifold. So tell me what I should do? Thanks
    Mark
  2. Havok
    Havok Senior Member
    Florida
    Turbo--that thing is pathetic without it.
    ks-motorsports.com
  3. pissedoffsol
    dont run the gsr pistons with boost...
  4. cws13
    cws13 Senior Member
    Athens,GA
    With 1 mm oversized valves and that manifold, it sounds like you are headed for turbo already. Might as well throw in the forged pistons/rods while it's apart.
  5. dwn2low
    Little Rock AR
    So turbo is the way to go? Well then turbo it is does anyone know where the best place to buy one is?
    Thanks
    Mark
  6. Havok
    Havok Senior Member
    Florida
    ... :rolleyes:
  7. pissedoffsol
    ks-motorsports for a street kit... full custom for a serious kit
  8. Integra1990
    Integra1990 Senior Member
    omaha nebraska
    for 1800$ u can get a jrsc kit on ebay, BUT i kno they dont mak them for the b18a, only the b18b, im not sure what the dif in the blower is, but its most likly the intake manifold...
  9. Domeskilla
    Domeskilla Senior Member
    Fort Wayne, IN
    The only difference in the motors are the cams, so i'm guessing it would fit.
  10. dwn2low
    Little Rock AR
    Thanks Guys you are awesome.
    Mark :worthy:
  11. pissedoffsol
    its more than that....
    it will bolt up no problem-- but some of the sensros and wiring is going to be different
  12. tdehnel
    tdehnel Senior Member
    Just a warning: 1800 dollars is nothing. When you say money is no problem, I hope you have a lot of it, because building a turbo or supercharged motor correctly (read: no cutting corners), it adds up fast. Not including the turbo kit (Greddy, with Intercooler), my turbo setup has cost 7100 dollars so far for parts and labor.
    Back to the original question: Turbo is by far the coolest of the 3 options. It'll net you more power than a supercharger (if you want to upgrade your turbo), and if done correctly, can be just as reliable as a good N/A motor.
