MikeBergy
Blah blah blah....
Obviously there are ways to cool things in space other than convective heat transfer. Radiative heat can be tranferred in a vacuum. You also run into problems with things becoming too cold in space, so a closed system heat transfer system could be employed to transfer the heat generated by the laser to keep the electronics at nominal temperatures. Cooling and heating is no secret to the world of space travel. Not to mention, a large reservoir could be used to sink the heat from the system. The transfer rate doesn't need to be high as long as the system has the thermal capacity required to contain the heating for the time the weapon is fired. It might take several minutes to cool between shots, as that is the case for most of the lasers being tested, but who said that a space based weapons platform had to have a high rate of fire? As for a missile shooting it down, I highly doubt any of our enemies have access to any missiles capable of taking an orbiting platform out of LEO.
