NA D16z6/y8
SolPWR
im just curious of what others have in their D
please list your engine, mods, and est hp
Originally posted by Blanco@Sep 22 2004, 02:40 AM
This is what I'm going to be building for my '91 Si:
D16Z6
DC 4-2-1 header (because it's legal in Cali)
Injen or AEM CAI
GReddy SP exhaust
P29 Pistons
Zex/Comp Cams 59300 cam
KMS Manufacturing springs and retainers, good to 10.5k rpm (man. claim)
AEM 5 bolt cam gear
ACL main and rod bearings
OEM gaskets and seals
Hondata IM gasket
OEM timing belt, tensioner, water pump
ARP head studs
Three angle valve grind
ACT six puck clutch
Haven't decided on flywheel yet, something in the 12lbs. range
ZC tranny with 'teg axles
Hondata S100
I think that's everything. I'll be looking for 150-160whp.
[post=393366]Quoted post[/post]​
Nice setup, I would go with Honda OEM bearings though.
CX 1.5 block
Si (d16z6 head)
EX tranny
p28 ECU
AEM cold air
2 inch exhaust with crappy fart can.
It works pretty good, but its kinda slow still.
This swap was done with spare parts laying around the garage for my buddy who blew the bottom end on his Si civic.
According to compression calculator it has about 10:1 compression tho.
Planning to add cam, headers, bore throttle body and intake manifold.
y8
si tranny
fmcai
skunk2 im
skunk 2 camgear
crower 3 cam shaft
crower valve train
pnp job with a 2 angle valve job
arp studs and rod bolts
p29 pistons
stock head gasket
maybe running hondata or power fc
act stage 1
cm 8lbs flywheel
bbk throttle body
ebay 4-2-1 header
straight pipe with stock muffler
tokico illuminas
eibach prokit
now all it needs is to be put together.
92 4dr gutted
d16/b7 block
mild exhaust port job
vafc II
dc 4-2-1 racing header
no ac
double bent short shift
stage 1 crappy clutch
small 2in exhaust .
runs pretty good and beats my friends ls with full intake and my other friends hyndai tibiron(dohc 1.8) stick :worthy:
delsol d16z6
aem full cold air intake
dc sports header
aem full rail
255cc spark plugs
8.5 mm wires
aem fuel pressuer regulator
62mm throttle body
msd ignition
centerforce clutch
short shifter
consider resurfacing ur deck for a lttle xtra compression
