90B16a1si Member Nov 2, 2005 #1 Name that trans! 25mph in 3rd about 2500rpm 35mph in 4th about 2750 45mph in 5th about 2750 50mph in 5th about 3000 Wheels are within 2% of stock diameter. b16a with cable transmission, y1?
reikoshea HS Troll...And Mod Moderator VIP Nov 2, 2005 #2 stock diameter on what car. mind givin a brotha a wheel size? with 175 70 13 (stockish tires) a Y21/S21/S4C (trannies that come with the del sol vtec and 99-00 civic si) you will be getting those speeds
90B16a1si Member Nov 2, 2005 #4 I tried to find the stamping. I even wiped it down a bit but I can't read it. I might try some solvent or something. The tires are 205/45-16. Actually, I may have calculated them as 205/40-16 so there might be a bigger difference than I thought.
P posol RETIRED Nov 2, 2005 #5 play with this: https://hondaswap.com/threads/gear-speed-calculator.59344/ you can grab gear ratios from the reference section. plug it in until you find one that matches.
