Need A Answer
Discussion in 'Engine Building' started by b18b, Jan 22, 2003.
  1. b18b
    b18b Senior Member
    ok i have a b18b1 with eagle rods and je pistons 9:1 that im fixing to install....i have a JRSC as well...my Q is this...at 10 PSI with a block guard will i be ok? i know my pistons and rods are fine....if i sprayed would a block guard still be ok ...maybe a 50....i dont want to sleeve if i dont have to cause im fresh broke..but if i need to i will cause i want to do it right its just i cant wait around forever to get my motor put together....thanks in advance for any suggestions
  2. phunky.buddha
    Dallas / Fort Worth, TX
    Tune it well and you should be ok with a stock sleeve and guard. The B18B can hold quite a bit of power if you treat it right!
  3. b18b
    b18b Senior Member
    alright thanks man....oh by the way is water injection a good thing to have if so im thinking about getting it
  4. prawjEKt Cx
    prawjEKt Cx Senior Member
    upstate NY
    dude you'll be fine on your setup, look into propane injection when you wanna boost like a baller.
    import power online
