Need A/c Help
Discussion in 'HYBRID -> EG-EK / DC' started by justkobi, May 19, 2003.
  1. justkobi
    justkobi Junior Member
    Just put a 95 LS into my 92 CX Hatch. Do I need to fabricate a bracket for the civic a/c compressor or try to adapt the civic lines to the integra compressor? :unsure:
  2. solblu
    solblu Senior Member
    Ricer
    You need a Del SOl VTEC AC mount.
  3. justkobi
    the delsol mount is it for the sohc vtec or the dohc vtec only one i can find is for the sandan compressor is the sohc vtec
  4. solblu
    Ricer
    A Del Sol VTEC is DOHC and it's only going to be available at the dealer.
    Cheapest is Hparts.com
    P/N 38930-P54-000 $97
    I'm pretty sure your compressor bolts right on.
  5. justkobi
    Thanks for the help I thought the SOL was DOHC VTEC but my junk man had me doubting. I ended up doing some welding and grinding and everything is back together. I have accounts with my local honda dealer but no one here has a clue. I usually have to go in and search my own parts. :worthy: thanks again for the help
  6. bluepearlintegragsr
    bluepearlintegragsr Member
    im also pretty sure that there is a SOHC VTEC sol aswell......... :eek: imagine that
  7. E_SolSi
    the SOHC non-VTEC is the S model
    the SOHC VTEC is the Si model
    the DOHC VTEC is the VTEC model
    so if someone is talking about the Del Sol VTEC.... they are refering to the DOHC VTEC model
