need a little help - Thanks!
Discussion in 'HYBRID -> EG-EK / DC' started by stevec, May 23, 2008.
  1. stevec
    stevec New Member
    My son has a 92 Hatch with a B16a swap in it
    I think his alternator just went out and I need to know what kind of alternator do I buy for it... like at autozone or kragens
    he said it is important to know that it is OBD1
    can you help me?
    I need to know what to ask for when I go to the auto parts store to buy the new alternator
    Thanks a bunch!
    Steve
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    tell them for a 1995 del sol with a dohc b16 in it
  3. get_nick
    Washington State
    have the battery tested first. might be able to save some money.
  4. AHHVTEC
    Alabama
    yea just test them both to make sure
  5. BrutalB83
    Rochester Hills, MI
    You'll probably want to ask for a distributor from a pre-96 Del Sol VTEC. As far as I know that's the only car that had a B16 in the US before the 99-00 Civic Si. OBD2 started in 96, so you should be safe asking for one that's pre-96...
  6. get_nick
    Washington State
    he's looking for an alternator nto a dizzy
  7. stevec
    stevec New Member
    thanks for all the quick replies!
    you guys are great
    We put a different battery and it started but the battery light was on, then it died while he was driving it
    he had degreased the engine compartment and when he started the car a bunch of smoke came out of the alternator, that's the day it stopped working
    seriously... thanks again!
    Steve
  8. get_nick
    Washington State
    haha, oops. sometimes you have to learn the hard way. ^_^
    edit: on that note, make sure when cleaning he stays away from the distributor also. that is an expensive and annoying part to have to replace.
  9. BrutalB83
    Rochester Hills, MI
    Woops! My bad! :mellow:
    Same thing applies though, for replacement parts look into the pre-96 Del Sol VTEC...
  10. stevec
    stevec New Member
    thanks again guys
    autozone has one for 140 bucks
    a kid here has one that he says pretty sure is good for 40 bucks
  11. rdomeck
    rdomeck New Member
    Indianapolis
    I have had nothing but bad luck out of Autozone's electrical parts. Try for a NAPA. Yeah the have a lifetime warranty, but you will spend your lifetime replacing them!
