need a little help
Discussion in 'Civic and del Sol - EG and EK' started by mintoxik, Jan 31, 2009.
  1. mintoxik
    mintoxik Member
    Oceanside
    well my honda won't start right first I had no spark I fixed that but I still have this high pitched whine while trying to start. Motor turns I'm getting gas and spark and it putts every other turn or so.
  2. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    timing correct ?
  3. mintoxik
    mintoxik Member
    Oceanside
    ya checked 3 times
  4. AHHVTEC
    Alabama
    are the injectors firing
  5. mintoxik
    mintoxik Member
    Oceanside
    the only thing i have read on it is it could be the starter solinoide but the motor still turns
  6. mintoxik
    mintoxik Member
    Oceanside
  7. AHHVTEC
    Alabama
    what check codes are you getting if you have any
    1 person likes this.
  8. mintoxik
    mintoxik Member
    Oceanside
  9. AHHVTEC
    Alabama
    maybe try a different ecu, borrow one
  10. mintoxik
    mintoxik Member
    Oceanside
    cool i'll try it i just hit the slavage yard tomorrow
    I am going to mess with it tonight yet let you know if i get it :)
    thanks man
  11. AHHVTEC
    Alabama
    i hope that helps if not i would try a compression test next
  12. mintoxik
    mintoxik Member
    Oceanside
    its not my ecu anyone got more ideas
  13. AHHVTEC
    Alabama
    compression test
  14. mintoxik
    mintoxik Member
    Oceanside
    so if it is the compresson how would i fix that?
  15. AHHVTEC
    Alabama
    rebuild most of the time, if your lucky its just a valve or head gasket
  16. mintoxik
    mintoxik Member
    Oceanside
  17. PYSPR
    PYSPR New Member
    Cali
    firing order rite? is ur dizzy rotor screwed on tight, sometimes those screws come loose so you'll still have spark, it will just be to random cylinders.
  18. mintoxik
    mintoxik Member
    Oceanside
    never thought of that but anyway I have NO compression
  19. mintoxik
    mintoxik Member
    Oceanside
    I got it fixed its the head so I put my old one on but dont have the right ecu
